I've ran herculiner and Monsta Liner, and Monsta was way better. My herc chipped and was very thin, I'll give you a couple shots of the Monsta. Herculiner is like paint with rubber chips, Monsta is a bed coating with a catalyst. Herc will eat your knees for lunch and then when you put something scratchy in there the rubber will scratch off. You shovel stuff out of your bed, I promise you don't want herc. I also know a bunch of guys who run Al's bedliner, it is similar to Monsta Liner and again those guys love it. Al's is catalyzed as well.
Having said all that, LineX is way worth the extra money. I ran it in 3 trucks, great stuff. I use the roll on for the tub, but something like a truck bed you can't afford not to use LineX. You couldn't get linex to scratch off if you tried, I shovel dirt out of my truck around once a month, and never even had a chip.
This link shows Monsta versus most other roll-ons like herc. I ran herc in a van tub and scratched it off in two places in a couple weeks, I didn't have any issues at all with the Monsta. If you join the Jeep forum they give you a sick discount and free chassis saver. I think I pad 125 bucks and got some chassis saver as well. One gallon with activator is 128, the entire kit price is 148, and a two gallon kit is 258, looks like it is a little
cheaper on ebay, 145 but you can't get the extra rollers. The DIY with the Performance Catalyst's work better and are stronger. If you do get it, I recommend the kit and not just the gallon. The texture brushes is what gives it texture, not rubber chunks. I would even order an extra mini roller kit for 4 bucks for any tight spaces or touch up, and one extra reg roller for 3 bucks. I remember I used up 2 rollers and wished I had a third for a second coat. 2 coats give more texture and thicker coat, I think you can get 2 coats on if you have a 6 foot bed with one gallon. Because you cant do bed rolls, I'm sure you can get one good coat and at least a second coat on the floor that will see most use. In fact I would use an old gallon can and mix 1/2 at a time, that way you can have a thicker protection. If you mix it all at once it will harden in the can, that is why if you want 2 coats to split it up. If you choose Monsta PM me with any questions.
Just looked it up the current promo is free shipping and free chassis saver, codes are here. So you don't have to koin the jeep forum, lol. But you might want to google it and check out the thread of monsta liner jeep forum, it has 1 millions views and a ton of guys ran the stuff in their jeeps, colors as well.
FREE Chassis Saver Code: FREECSQ13
FREE Shipping Code: FREESHIP13
line-x
Monsta 1
m2
m3
Free chasis saver is great as well, paint right over rust. Before and after pics
before
after
