OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Philadelphia, Pa
- 2020
- Hemi 5.7L
So i know the low/high beams need can-bus/capacitors and the turn signals and brake/reverse bulbs need resistors etc. But i could have sworn i seen somewhere on here that atleast for the 09-12 Rams that the canbus system does not monitor the fog lights so therefore you dont need any special adapters or capacitors like the headlights.
So basically can i throw in any fan cooled H10/9145 LED bulb into my fog lights without needed any anti-flicker can-bus adapter/capacitors?
Can someone who knows or has installed led bulbs themselves please answer me. I want to order some led bulbs with the cooling fans on them for my fogs but i need to know if i should buy the adapters aswell.
Thanks.
Sent from my LGLS775 using Tapatalk
Thanks.
