Do you wax or seal?
14RamMan
Up until recently, I didnt know there was a difference. I purchased some sealant and a clay bar kit off amazon and will try it in the next week or 2.
My question is, do you wax or seal your paint and why?
Sohc1997
5.9L
I do both, sealer Is used to seal in your work aka compounds, polishes. Wax is used to protect your sealer.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Exactly what Sohc1997 said, both. I clay bar, correction polish, finish polish, paint seal, and then wax. Then Guard and Gloss at wash time over that.
The sealer will last a lot longer than wax but typically isn't as glossy or shiny. So waxing over top of that with a good carnuba wax will bring the shine back up and help your whole system last longer.
14RamMan
14RamMan
interesting. I feel like Ive been living under a rock
Buckfat
SW FL
Clay bar
Seal- Rejex
Wax
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
As of this year I do both. I seal with Wolfgang deep gloss paint sealant 3.0 and wax with Collinite 845. I also clay bar and polish once a year.
Ram444
Cummins 6.7
I've been old school wash and wax. I'm going to try this technique and see if it is substantially better. I've already washed one side of the truck( it's freaking huge) and clay bared it. I do have a scuff that needs addressed.
Ram444
Cummins 6.7
Another prior to clay.
kevperro
Pentastar 3.6L
I use the Classe twins once per year. I use a Quick Detailer & spray wax every couple weeks. Clean as a whistle and it really takes minimal effort. What takes effort is when you let it go for months on end. If you buy the right product and use it regularly keeping it up is not that hard nor expensive.
Scgirardi
Ever look into coatings. Brings shine and protection for years.
Burla
2010 Hemi Reg Cab 4x4
Would you go over your sealant with something like acetone right after applying it? That is what you do when you wax over sealant. sealants are usually low voc and waxes have to be high voc, IE solvent. Wax is great for show cars and if you are going on a trip because it tends to give more protections against things like tree sap, it is a thicker coat. But it will also trap contaminants on your paint over time. So what I like to do is take Zaino all in one cleaner and top it with z2pro or z5pro. I like the klasse twins as well, I get more longevity from the zaino personally and I believe the zaino pro's seam to look deeper. Wait a while between coats. Anyhow, the all in one cleaners seam to leave the surface perfect for sealant, and I have tried most and Zaio and Klasse AIO are the best I've tried.
CLOUDL1GHT
Lone Star State
Cummins HO
Right now I'm using HydrO2 from CarPro and once I finish the bottle I'll buy Reload. The stuff is amazing
