What r u waiting for?
Post pics when ur done.
You have no idea how many small things had to be done lol. I used a piece of unistrut as the main support for the lights, I had a 3' piece so it would span from bumper mount to bumper mount and I could bolt it directly in, I had to get 2 steel plates and cut them slightly since I did a body lift the lower part of the bumper mount was at 2 different depths and the unitstrut would not sit flush it ended up being in an angle so that is where the steel plates come in, I had to put the bolt through them and slide them behind the unistrut so it was flush with the other surface it would be mounting it to making it all one level surface. Then I finally was able to mount the unitstrut then I had to measure what holes I was going to use to space it apart evenly. After that I had to measure where I was going to cut the plastic insert for the lower bumper portion, I used a dremmel and I cut out the measurements I took and sanded them down and filed them smooth so it looks good. FINALLY I mounted the lights and loosened the mounting brackets from the unistrut slightly as to move them around for final install and ****.
Materials were as followed
3/8-24 Grade 8 bolts 3" long-2
3/8 Grade 8 lock washers-2
3/8-24 grade 8 nuts-2
3/8 fender washers-2
and other **** came with lights other than smaller lock washers I used on mounting arms for light and smaller washers for it.
TLDR: It was a ******* ***** to mount them how I wanted but I did it and they look kickass!!!
I didn't take any pics as I was doing it because I was more focused on finishing it.
FINISHED PRODUCT
