figured id give an update on these, so far through rain and everything else they have been working good, they are close to the same output as OEM projectors so in that sense they are a decent lighting option for anyone not wanting to do nothing more than plug and play on a budget...
now i will list the few negatives...
first negative is the adjustment, on my passenger side headlight the adjustment came a little stripped out and is a little bit of a pain to adjust, have to hold the screwdriver just right and put a little bit of pressure to make it adjust, the driver side works perfectly, could be a random thing but thats how mine came...
my other issue, which hasnt really been an issue, people mention fogging, well mine do have a small fogging issue, now before anyone assumes that water is building up in them, when i say fogging i mean that its like the OEM projectors fogging issue, sometimes there is a very slight fog that comes around the perimeter of the light, but it only happens when the headlights are ran for an extended period of time and the fogging goes away in about 30 mins after they are off, i saw more fogging on my oem projectors honestly, so to me its not a leak, it is only a temperature change thing, i havent tried to look for a vent or even take them off to inspect them, like i said its only on cool mornings do i even notice anything and after around 30 mins all fog is gone, no leaks, no moisture no real complaints so far, i will be taking these apart to remove the amber and i can get a better look at things, but overall i still say these are a good buy for these trucks
