Express Side Mirror to Sport Conversion?
Aikido187
Is it possible to put side mirrors from a Sport on an Express and make the turn signal/puddle light work?
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
:Big Laugh:
You just need to buy them and add two sales codes. Some one will be along shortly to tell you what they are, because I can't remember.
Ricks Ram
Sales codes are LEB and LEC. You need to make sure the mirrors are from a 13 or newer as the outside temp sensor is mounted in the mirror on these years.
A
Aikido187
Thanks for the info. Can you change the bulb inside the turn signal or do you have to buy the whole turn signal assembly?
maple
San Bernardino CA
The is lights are LEDs and I'm not 100% sure but I don't think u can just buy the light I think u have to buy the whole mirror ( I did the upgrade on my express I had the dealer active the puddle light with Leb and lec sales code) the mirrors are plug and play other then that if u get a set with power fold u will need to change out ur buttons so u can have that feature as well
Booms
The OG
Ocala
2015 Express
Smoooth..... :D
BUGGS99
Minneapolis
I still have yet to add the sales codes to my sport mirrors I put on my express. Is this something you can do or does it have to be at the dealership?
Ricks Ram
The sales codes need to be added by the dealer.
A
Aikido187
What happens if I buy the side mirrors with the power folding option but don't change out my buttons? Would everything else on the side mirrors still work, just minus the power folding option?
Kytow
Any idea what to expect for the charge to do so?
Also I imagine you would need the PCM to be set at stock
Sent from somewhere with confusion.
Redram15
Co
Mirrors
Anyone know how to wire them directly
Solid State
2011 Bighorn
Ss stated, sales codes are LEB and LEC. I think your truck had to have the option grom the factory. I've heard anywhere from $60-150 to add the codes depending on the dealership.
Redram15
Co
I've took it to the dealership they charged me 150 they still don't turn on anyway of knowing that they did add the codes?
Rzrman328
The treeline
Couldn't power just be ran from the front turn signals to the mirrors to come on at the same time and skip the code debacle?
Redram15
Co
Do I run a wire straight from the turn signal to the mirror what about the puddle lamp what color wire is for the turn signal on the mirror
Rzrman328
The treeline
That's what I would do.
As for the puddle, idk which wire it is for sure but once you found it, I'd just tap into the cargo light circuit so they come on with the fob.
Edit: same for turn signals, not sure which color wire it will be.
Redram15
Co
Do you know if I can tap on to them closer to the mirror what color is the turn signal
VLG6963
