Front end noise
Rocky221
I have a 2012 2500 4wd. I've had it for about 2 1/2 months and since day one I have a weird grinding/rattling noise in the front end when turning left or right from a stop position. Doesn't happen all the time just periodically so I can't get it to duplicate for the mechanic. So far they have done both front u joints, passenger side axle, drivers side tie rod and drag link with sleeve, a ball joint ( not sure which side) and still continuing to make the noise. They are paying for parts and labor but I just want it fixed.
huntergreen
Have you looked at the wheel bearings? Any grease fittings that are going dry ?
R
Rocky221
I haven't checked. Trucks back at the dealer yet again. So I'll have them check in the am
RamCares
Michigan
n/a
n/a
Hi Rocky221,
Please keep me updated on your appointment, I'd be happy to assist further if needed. Just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
R
Rocky221
Hi Rocky221,
Andrea
Ok I will send that once I get my truck back. As of now they are changing a hub and speed sensor to see if that is the problem. Also it's great when you pull up to check on status of your truck and the mechanic is peeling out in the truck 3 different times.
huntergreen
Did you ask him why he is beating on your truck?
R
Rocky221
I let the service advisor and manager know. They wouldn't let me speak to the mechanic. Picking truck up this afternoon and gonna see what else they have to say or do.
R
Rocky221
Finally think they found the problem. Rotor was cutting away at the drivers side speed sensor wire. So anytime tire was turn right was causing the abs sound
huntergreen
Good to hear they found the issue.
R
Rocky221
Noise is still happening. Guess they didn't find the problem.
Burla
2010 Hemi Reg Cab 4x4
You got the solid, so I would look at the brake system before anything else. If it is a 2012 and has around 50k you are probably due for a brake job anyhow. I wouldn't trip on that mechanic, you said yourself it is hard to duplicate, I'm sure he was trying to get it to make the sound.
Only when turning though?
R
Rocky221
I'll mention the brake system today to them. Dropping it back off again. But when the noise happens brakes aren't being applied. It happens from a dead stop turn, like turning onto a side street from a main road. Also has happened a couple times at 20-25 mph down a bumpy curvy road.
