Getting Ready to order tires, just want to make sure!!
sunkiz
Hey Gang.
2011 RAM1500 BigHorn Crew Cab.
I am ready to take advantage of the discount tires offer on Ebay, ($100 off $400 with $70 MR)!
I have installed the Stein 5100 @ 2.1 and upgraded with Mevotech UCAs.
Ordered the 20" Fuse Maverick -24.
Will 296 55 R20 (34/11.6) Cooper AT3 fit my Bill without rubbing?
I can get them for $266..5 a piece after rebate, ship to my door. Ready to pull that trigger. I know sending them back to the seller is very expensive if they dont fit.
If anyone on this form have similar setup, please post some picture or point me to some..
Thanks.
Ravjay12
With -12 offset you should be fine.
quietpeen
2021 TRX
Hellcat
chances are you will be fine because 295/55/20 isn't 34" tall and you are looking and an A/T tire vs a M/T with aggressive side walls
I have the 20x10 Fuel Mavericks with -12mm offset wrapped in 295/60/20 Toyo M/T's and i get slight rubbing at full lock to the left and my bilsteins are also set at 2.1
edit: just looked up 295/55/20 and that is a little less than a 33" tire so they will fit fine
1Popeye
