Headlight Retrofit
Muddy13
Hello looking to do this with my headlights and was wondering if anyone ever had any problems or complaints with the pods as high beams and wiring any input would help thanks here's the pic
Rzrman328
The treeline
Subd.
I'm trying to figure out how I can do this with my dual's.
2014moparam
3.6 V6
Don't have any experience with the pods, however, why not just retro in a projector and hid lighting? With how much of a pita it is to bake headlights and such, if an led goes out, that's a hella lot of work to replace a pod..
I would assume with the correct resistors and capacitors in there, shouldn't cause an issue. I would hit up JJ at retro shop, as he would probably know 100% what you will need.
adurm
FL
2015 RCSB
^that
Etroze86
Grand Forks ND
Subd.
The edge LED strip is a no go so far for the duals. If you like the square look of the LED's I do have the Square projectors that Mirimoto make that are mounted but I haven't gotten around to sealing the headlight yet. They fill our duals out nicely.
M
Muddy13
Hmmm ok so maybe I don't wanna do the led pod and just use the regular high beam how hard is the rest of it if I'm pretty mechanically inclined or is there threads for doing such
2014moparam
3.6 V6
Are you wanting to do a low beam retrofit? Projector lenses and HID's?
maple
San Bernardino CA
I want to do this as well, how often do these led pods go out?
I have a set pulled apart and waiting for my factor paint to come in. I wanted to do the projectors on top but i dont want to do hids, is there any way to put a projector len in the top without a hid kit?
Paluby
Alaska
Man that looks so badass if you could pull the entire thing off.
amdwilsns01
