Hey, thx a lot for this post....And your limitless headlight knowledge...lol
You saw the new headlights I ordered recently and I went back to look. Sure enough, H1 bulbs for the lows. I had ordered some new bulbs (4000k halogens...whoopty) in the stock size lows/highs, but see I need the H1 instead. These will just be Philips crystal vision ultra for now. They are cheap....What Sylvania/osram prices should be for these type bulbs.
This will get me by until I go HID in the projectors....Do I go morimoto or something else?
Your welcome! When i first bought my Ram i knew nothing about the lighting in it, but over the last 4 or 5 months ive learned everything i know from these forums, google and other forums. You shouls try searching these forums for hid or aftermarket headlights or spyder, etc. There is a ton of info already on these forums so you can learn almost everything you need to know just by reading old threads.
But about your headlights, I saw a youtube video of a guy who bought a Morimoto h1 hid kit for his spyder headlights and the h1 hid bulb would not fit into the spyder headlights because the glass part of the bulb is too long and hits the glass of the projector lense before it can be turned and locked into the housing.
Those spyder "projector" headlights are made for halogen bulbs and not meant to have hid's put into them. If you really want to upgrade the bulb to something better then halogen you could always try buying an led bulb that is meant for a projector lense. The h1 led bulb should fit inside the projector, unlike the h1 hid bulb, as hid bulbs tend to be a little longer then halogen and led bulbs.
