msearam
Got a 2" level installed and an alignment, which I don't think was done properly. Drove fine with a little pull to the right. A couple days later I got new rims and mounted the stock tires on them. Noticed vibrations at 80kmph and up. Got them balanced twice with still the same problem. So tomorrow I'm going in for a road force balance and alignment. But any other suggestions? The vibration is felt in the ass end and the steering wheel vibrates also. I got hub centric rings also but that didn't fix the problem.
Any ideas???
Thanks for any help, I don't want to keep throwing money at alignments and balancing so if you know any other causes I can start looking into that would be great!
Thanks a lot,
Matt
Any ideas???
Thanks a lot,
Matt
