Hid lights
trevorhall__
Hey has anyone installed HID kit in the 2017 Dodge Ram sport with projector headlights? If so did you have any problems with flickering or error messages?
16laramie4wd
Enlight hid kit on 16 with projectors.... cree led bulbs from opt7 for fogs
T
trevorhall__
Do you happen to have a link to this kit?
Ram Night
Southwest, Michigan
I installed the 35 watt 5500K HID kit from The Retrofit Source, and they really work great and brighter than any led. They sell a kit that is designed for our 2015+ trucks. You will want the kit with the 9005 Bulbs.
https://www.theretrofitsource.com/vehicle-specific/trucks/2015-mopar-morimoto-elite.html
Check out the before and after photos. Stock Lights, HID low and HID high, and the last one is HID low beam with Diode Dynamics XML2 led fogs. With the projector lights you only need to replace the low beam bulbs. The shutter will do the rest for you. :favorites13:
T
trevorhall__
Yeah that's the kit I was loooking at, but no one had good pictures to see. Yours are good! How do you like it? Have you had any issues with error messages or flickering?
T
trevorhall__
Also did you do a fog light up grade? I know I can't put HIDS in but led?
Ram Night
Southwest, Michigan
No sir, no issues with flicker or light out messages. The TRS kit comes complete with modules, relays, and resistors.
Ram Night
Southwest, Michigan
Here are a couple of photos where I mounted the load resistors, and the modified light housing cover.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
That a great HID cut off pattern. Mine needs adjustments.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
That's a bummer, Hopefully it will be a quick adjustment.
I have the same cut off pattern on the 16 Rebel and 17 Sport.
Your bulb wires are 6 o clock? Thats why mine aren't sharp.
madtrucker2016
New York
2016 Laramie installed 55 watt in the projector headlights and 35 watt in the fog lights H I D what a difference love it cost a little but worth it.got them from GTR lighting on line they are plug and play direct no wiring with stupid relays and all the other crap just plug them in and your good and no messages from them on the dash they are made just for the electrical on your ram trust me they work great:Caffeine:Also the parts and bulbs are warrantied for life free replacement they just send you new stuff can beat it any part goes they replace it free
PumpkinStealer
Dubuque, IA
I have the morimoto mopar elite 15+ kit and enjoy it but have had nothing but problems. Had a ballast go bad but it was replaced for free. I also have had a bulb out warning since I got them and they tried replacing the resistor but it didn't work.
They told me they didn't have a fix and that was it. Now that winter is over I'm trying again and they at least seem to be trying harder this time to help fix it.
To anyone with them, where did you place the ground wire at? Existing ground or new screw into metal?
Jimmy07
Since the discovery of the AlfaOBD software, which lets you change the low beam BCM setting to HID, everybody’s been placing the ground wires in the garbage (along with the resistors and relay harness). No more rats nest wiring, bad resistors, or bulb out warnings.
Midnight Storm
One Badass Ram
Victoria, B.C Canada
That makes me happy! I ordered the 55 GRT smart Kit mid March. Unfortunately due to Headlight revolution moving states and some stocking issues, I’m still waiting for them to be shipped. 41 days to be exact..
I’m getting a taste of what you XB headlight guys went through. Sucks!
madtrucker2016
New York
WOW didn't know they moved got a email from them but I didn't read it got my stuff for Christmas so really no contact with them but after install they mailed:Caffeine: a new ballast with problem in 3 days to me. well hang in their they seem like good guys if you email them from their web site they are fast to get back to you
