Hopefully a quick trouble shooting HID question
Moundman
2009 Dodge Ram 1500
I installed an HID kit from Jeremy at retroshop this spring/summer. Everything has worked great until a couple weeks ago. When I started my truck neither of them came on. I left the switched in the on position and few minutes down the road the lit up. Since then I've had no issues. Last night on the other hand I noticed when I started up the truck and turned them on they wouldn't light up again. I left them on thinking maybe the same thing would happen but it did not. Today I got the same result. No lights.
Could it be the ballast? All the connections look good so I'm not what else it would be.
Any ideas would be greatly appreciated.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
What a pain in the butt. I would be screwed if that happened to me on my daily commute. It's very odd that both of them aren't working at the same time. Just to rule things out, have you tried connecting the OEM halogen bulbs up and see if they work? If they do, then I would think ballasts. I'm not really sure though. The fact that both won't come on really has me wondering. Call JJ...there's a 3 yr warranty on his kits. Please keep us updated with what you figure out. I also have his HID kit on my truck.
Moundman
Moundman
2009 Dodge Ram 1500
Emailing back and forth with Jeremy today. He's having me check some things like corrosion or bad connections because to him it sounds like a bad connection.
I did that and so far nothing yet. I just emailed him so now I'm waiting.
I should just break down and send him my old lights and have him completely overhaul them. :)
BlackRamHemi
Edmonton Alberta Canada
I take it you have the relay harness? stock Quad lamp?
Time to upgrade to 13+Projectors with HID's and CanBus adapters...no more harness
Pigeonman
Alberta, Canada
Occasionally my passenger side light won't fire up when I unlock the doors with my remote. If I lock it and unlock it again it usually starts up. Flickers a bit but seems fine once it warms up.
Mine are in the factory projectors with the CANBUS harness.
Moundman
Moundman
2009 Dodge Ram 1500
My wife tried doing something nice for fathers day and bought me some black spyder lights. Not my choice but she was thoughtful so I thought I'd make them work. Jeremy helped me out by telling me what HID kit to get from him and thing were pretty good. lol
But yeah my originals were quads.
Hemi_Express2013
Nantucket, Ma
Happy wife, Happy life! It's the golden rule. Have you done a continuity test on the wiring harness? It would rule out a short in the harness?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
When they both go.......I always think:
- fuse
- corrosion or bad connection at the harness
- capacitor bad / corroded, ground off?
VERY odd for both to just flake out though......
iam_canadian22
northern ontario
Sounds like a bad connection, check them all good, i has similar issue and was one of the pins in a connector pushing out when connected, hard to find so look hard, considering its both lights its likely something to do with the harness or the relays, check from the connection to the stock plug inside the drivers side light and work your way to the relay from there, seems like you intermittently lose power to trigger the relay
Moundman
Moundman
2009 Dodge Ram 1500
Thanks for all the suggestions. I disconnected the lights and plugged in the oem ones. They worked fine. I then plugged the hids in again and they worked. I'm guessing it just wasnt making connection like most of you guys said. Thanks again for all the help. Jeremy thanks again for the emails.
Hemi305
Miami, Fl
Hey guys, i have a similar issue. I have a set of HIDs on my 2012 ram 1500. My left fog light flickers and wont turn on and one of the horns dont work. I was thinking it was a relay issue but not too sure. Any ideas?
iam_canadian22
northern ontario
What kind of kit? Does it have a capacitor or canbus adapter? Fogs get tricky, theres quite a few that run them plugged directly to factory plug with nothing else and no issues, then theres also quite a few, myself included, that need a harness with a capacitor or a canbus adapter to get them working properly
Hemi305
Miami, Fl
I have a canbus kit that have worked perfectly for about a year now. I just tried them on another car and they worked perfect so it had to be the truck
Agron1979
Fort Worth, TX
That's a bummer....good luck with everything, and I hear Jeremy from Retro Shop is the man so I think he'll get everything done right for you.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Its hard to diagnose other companies stuff.........assuming its not mine, as your sig reads 8K....we go to 6 ;)
I'd check your grounds.
