How can I get REALLY bright reverse lights?
MaxSteelRam
Swapping to LED from bulb will definitely help, but what LED should I look for specifically to get the brightest reverse possible? I have tinted windows and my driveway is pretty long, would like to be able to really light it up well.
RAMblin1217
Why not mount spot LED lights in the bumper or under it? I also have a long driveway but with the backup camera it isn't too bad. Other option is to just light up the edges of the driveway like airports do runways. Even the brightest bulb in the reverse light housing isn't going to do all that much if this is that big of an issue for ya. I have 5% tint and smoked taillights so I feel ya.
perk7089
Cummins 6.7
Yes I usually just wind down my windows even with LED reverse lights and LED spotlights under the bumper
Sent from my XT1080 using Tapatalk
MaxSteelRam
MaxSteelRam
i definietly don't want to mod anything to add external lights, and under the bumper sounds like a place to rust (salt belt).. so not too sure.
RAMblin1217
Cheapest solution is get 10-20 solar lights and line the driveway with them. However under bumper isn't going to rust out quality lights made by Rigid sincemost of their lights are made for tough weather and getting beat up, however they are expensive.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I had some plug and play LED reverse lights in my 2011, not sure if they will work on my 2015...<shrugs shoulders>
Rzrman328
The treeline
Add pods....they'll blow away ANY LED bulb you stick in the oem housing.
No rusting.
DailyRam
North Carolina
Did you T-clip into it? I guess i'll start looking for the pin out for the trailer harness to figure out which wire to tap into.
Rzrman328
The treeline
Yessir.
Off fuzzy memory but I think it's the middle wire? I'm not home to check.
stimpy433
IOWA
Pretty sure it's the middle wire of the 7 pin.... if you look on the cover it shows the pin out on it.
MaxSteelRam
MaxSteelRam
really like this pod idea.. just need to figure out which to buy and how to wire.. thanks guys
jgruberman
EcoDiesel 3.0L
Wired off the white/orange in the trailer harness. Don't judge the tape job, was in a rush :)
