just bought 20x9 0 offset wheels and 33x12.5x20 tires. how much past the fenders will the tires stick out. trying to decide between pocket flares that cover 2" or oem 2500 flares. I'm also leveled on bilstein 5100s
should be about the same, correct? doesn't matter that mine are 20x9?
So 20x9 stock offset is 19.4 mm offsert-roughly 5.75" backspacing. That means that a 20x9 with zero backspacing has 5" backspacing which is .75" less backspacing than Stock so the wheel itself sticks out .75" further than the stock wheel
what's the stock tire compared to a 12.5 wide?
got it. 10.8". so about 1.7 for the tire and 3/4 for the rim. it'll stick out almost 2 1/2 inches?
new tires are 1.5 wider than stock. looks like it is gonna be close to 2.5 with offset . I'm either stock 2500 or egr bolt on. doesn't look like stock flares would coverage that much tire
