Solid State
- Apr 18, 2016
- 824
- 487
- 2011 Bighorn
- Hemi 5.7
Installed the ICI Magnum rt steps on my truck today and thought I'd do a little review. Packaging was almost overdone. Everything was wrapped and protected incredibly well. Shipping weight was 91 lbs. First impressuon is that rhese things are pretty rugged. Much more so than my old SS steps. Install was fairly simple. Required no rivnuts, at least on my truck. They come with a little triangular bracket that goes through the factory holes in the pinchweld, and is very simple. Didnt take picture, but if you've installed steps before, you'll know what I'm talkinh about. The brackets the same material as steps, again pretty heavy duty. I like the way they attach to the frame (see pic). Two tips to make install a little easier. 1. Put everything together fairly loose, then push everything in place and tighten. 2. It would help to habe an extra set of hands to hold inbolace while tightening wverything down. Steps are very solid. I weigh #165, and not even close to feeling any type of flex. Very impressed with the quality. Took some messing around to get the fit right.
