Installed my Light Bar
Bcountry
Florida
I went with a 42 curved light bar off eBay that had the harness and switch included. I must say this was the easiest thing to install. I used 14g angel for brackets about 5in worth bored out the mounting holes and ran the wires. I trimmed the plastic grill piece and placed it back in the slot to cover up the side and the top where I had some gaps.
Bcountry
Bcountry
Florida
I luv the light output !!
stricnine
MOPAR
Nice, where did you mount your switch?
Bcountry
Bcountry
Florida
Ran the wires through the clutch plate and mounted under the rotary gear shift.I could clean it up a tad and tuck the wires behind the plastic
Ram75
South Jersey
2019 Tradesman
Looks great. Where did u tap into for power?
Bcountry
Bcountry
Florida
Straight off the battery via inline fuse and resister that came with the kit.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Awesome job!! Definitely thinking of doing this later this year!
Adam
Bcountry
Bcountry
Florida
Adam
Adam it was so easy this was easier to do then installing my HID's, I think the strongest and best bracket to use is the 14g angle you get from HD or Lowes all you need is one piece. The holes line up well just need to be bored out just a bit. Good luck PM me if you need more pics or info.
BlownGP
Houston/Baton Rouge
Nice job. I used the same wiring harness too. Works great.
Ronaldw
Florida
