Are these the harnesses I need if I go with the non morimoto kits? Also I will need it for the fogs too right?
https://www.amazon.com/gp/aw/d/B00J...g_3?ie=UTF8&psc=1&refRID=0DRTFP3NQXK1G37BYMFR
I got the Opt7 for my old 06 Quad Cab Ram and it eventually worked but I had to cut and spliced wires and switch all kinds of plugs around.... it was a huge mess and took over 8 hours to finally hook everything up right and figure out which wires went where because the instructions were useless because if you hooked it up that way it did NOT work on the 06 Rams.
Don't order the Kensun or the Opt7 kit. You are literally wasting money. You will get the kit and in the end it will not work for the 09+ Rams. You will then be out $60- $120 and have nothing to show for it.
Just buy the drop in kit from Retroshop.us. I'm pretty sure it's $150 and that's only like $40 more than the Opt7 kit if you buy the relay too. The kit from Retroshop is the best on the market and it's made for one vehicle and one vehicle only; the Ram. The Opt7 and Kensun kits are made for 100s of universal vehicles and they don't work on the Rams tricky CanBus system.
I can guarantee if you order the Opt7 or the Kensun kit, you will be back on these forums asking why it won't work and why it's flickering or one light works and the other doesnt.
Just save your money and buy the RetroShop drop in kit or don't buy any at all.
What kind of headlights do you have? Quads, Duals or stock Projectors?
Sent from hell via TapATalk
