LED Bulbs in lail lamps
scHemi
2009 RAM SLT Crew
Any way to replace the 3157 bulbs with 3157 LED bulbs and not have the computer tell you that you have a bulb out? And start flashing a million times?
lonestar21
CA
2019 Ram 1500 Big Horn
Nope in order to avoid that you'll have to use a resistor and cut wires.
In my opinion LED bulbs in the tails won't make a difference.
If you want it brighter your best bet is to buy an aftermarket led tail lights.
Good luck
S
scHemi
2009 RAM SLT Crew
Figured as much. I was just trying to avoid ever having to replace them again. Had nothing to do with brightness. Just me being lazy and cheap. Lol
BigDogg795
Ronkonkoma, NY
What about the VLED Tritons...? I know they're expensive but they seem to be very bright and they seem to have a plug and play resistor?
muscleram
If your being cheap just leave it alone or you will have issues.
As far as being lazy it's real simple to change he bulbs when needed
Sent from my SM-G935W8 using Tapatalk
