Chetperk
I just installed these LED Headlight Bulbs Conversion Kit PHI-ZES 8000LM 6500K CANBUS I bought from Amazon for 49.99. These come with the canbus decoder and after installing they work great. No error messages, no radio interference either. Everything fits inside the housing and the dust cap fits too.
The test will be to see if they last. So far so good. Very bright and has a decent beam pattern. I also installed Quakeworld LED 9006 fog light bulbs, which has the Cree XM-L2 led. Nice and bright. Big improvement over factory halogen.
Here are the specs for the h-11 head light.
SPECIFICATION
Input:1.0A¡À0.1A
Input Power:40W/Bulb
Luminous Flux:4000LM/Bulb
Color Temperature:6500K
Operating VoltageC12V-24V
Waterproof Rate:IP65
Beam Angle:360 degree
Operating Life:>30000hrs
Heat Dissipation Theory:Aviation aluminum 6063
Operating Temperature:-40~+80 degree centigrade
Specs for fog lights
PECIFICATION:
Power:20W/bulb,40W/set
LED Quantity:2PCS-CREE
Beam Angle:360degree
Beam model:Single beam
LED:CREE Led Chips (Designed for automotive)
VoltageC12V-24V
Input:1.6A +- 0.2A
Color temperature:6500K
Material:Copper Braid
Waterproof rate:IP68
CREE XM-L2 Chip:
1,Efficient thermal resistance 2.5degree/W
2,Excellent lighting effect and reliability.
3,High hot lumens,Stable hot lumen value after lighting on.
4,New generation LED products which base on CREE carborundum technology.
5,Efficient heat dissipation,Enhance lighting efficiency.
SPECIFICATION
Input:1.0A¡À0.1A
PECIFICATION:
VoltageC12V-24V
Input:1.6A +- 0.2A
CREE XM-L2 Chip:
