Working on uploading a picture iv got a fat bob garage 2" level 60$ on my 14 2wd with 2500 shocks for another 60$ it will more than likely clear 35's especially if you are adding a wheel space. Offset is the name of the game there's a guy on here with a 3" level running 37"s with a crazy offset and no rub. I also have mevotech uca's on the way and 1/4" spaces on all four corners. I'm going to run 35's once th stock tires are done. Weather they rub or not I've got the skills to trim plastic and order different spacers. I've looked into a 1 1/2 body lift as well but it really doesn't give you a ton of extra room. Hope this helps will try and get the pic up today.
