Leveling kit, Trail Grapplers Question.
vmavino7
5.7L HEMI
Hey all, new to the forum and will be going with the Hell Bent Steel leveling kit for a 2013 Laramie 4x4 and am wondering if the 295/60/20 Trail Grappler's will fit w/o problems or if it would be better to just go with 295/55/20.
Thanks!
johnnysart
Albuquerque
5.9 Magnum
Welcome, I'm sure someone will chime in soon.
FL BOY
Weeki Wachee, FL
295/60/20's are 34.4 inch diameter I think some guys are running 35's on
Just a level with the right spacer and or rim. I could be wrong though
monettejb
2018 Hydro Blue Edition Ram 1500
Greenville, NC
I have them on my truck with a two inch level but I also have a 1.25" body lift, but just eye balling it I dont see where you would have a problem.
Ona4day
Nevada County, Ca
I put 285/55/20 grapplers on my stock rims (express) with a 2" kit from Ready lift. I did have it barely rub on the sway bar at full lock for a little bit but it seemed to go away quick. No other spots. You might have slightly different rims on yours though. I know they have 20x8 and 20x9 out there and I'm not sure if the offset is different between them.
MoparMulisha
New Windsor, MD
You may rub at full lock, I'm sure one of the guys running the 295/60's will chime in.
They're running the 35's on factory wheels with 1/4" spacer
mexi
2013 Dodge Ram
i have the same truck and 2.5hbs with 305 55 20 trail grapplers and i dont have any issues
V
vmavino7
5.7L HEMI
Pics?
Do you have any pictures, I am a little concerned with it possibly "squatting" a little. I don't want that however really want to go with HBS because of price and reviews.
Thanks for the reply!!!
DIETEL42
Edinburg IL
I had a 2 inch leveling kit, now im running a Bilstein 5100 adjustable at 2.8, i havent had a problem with a 35x12.50x20 trail grappler with either.
skirider
I want to run them too hows the ride a wear mainly want them for look dont plan on going offroad
