lowered with 17's
borderram
Are any of you riding on 17 " wheels. I dropped the rear 3" and it just doesn't look lowered but my tape says it is. If you got pics please post'em.
WhiteExpress
Midland, TX
A 3" rear drop should give your truck a nose high stance for sure.
While a 17" wheel and larger sidewall will not appear as low as a larger rim / smaller tire combo, I assure you, if the OD is the same, it matters not!
charonblk07
Calgary, Ab
F1-A forged 349ci
I run 17s for my winter setup, the biggest difference between the 20s and the 17s is the 20s come with a 32.5" tire and the 17s come with a 31" tire, so the 20s fill the wheel well more. I'll post pics when I'm at work tomorrow since photobucket is blocked in camp.
