mixing tire
The hippie
cummins
for my 2015 ram cummins 2500, I plan to put firestone transforce on my right rear and thunderer CLT on the left rear.
They have the same specs, size 275 70 18, the only main thing is they have different brand.
Is that ok? Would the difference be negligible performance wise?
Just curious.
Just
Want to get info. Thanks
quietpeen
2021 TRX
Hellcat
I was always told obviously that 4 matching tires is the best but if you can't do that have the same for rear left and right and then different tire for front left and right
grizzstang
Calgary, Alberta Canada
Tires can be taller or shorter brand to brand in the same size.
I would make very sure they are the exact same height.
Devin1349
measure tread depth make sure they are no more than 3/32nds of tread depth apart also look at tread pattern you dont want a street tire on one side and have a m/t tire on the other
DannyMK2
Long Island, NY
2015 Power Wagon
id put the different tire as my spare and put the spare transforce into rotation. a different brand tire from the rest would drive me nuts.
