MOPAR 82211496AE running boards on 2016?
Alfonso713v
Hey guys new to the forum here and I need some help. I just purchased some used running boards MOPAR 82211496AE and when I got home I looked them up and found out it only fits 2010 model 1500 crew cad. I have the 2016 cre cab . Am I screwed ?
daveray9
IIRC the mounting points on the rockers never changed from 09 and up. So you should be fine. Im running ones off a 2014 on my 2012 so.
quietpeen
2021 TRX
Hellcat
can't say weather or not they will work. As you know the part numbers are different....to me the mounting brackets looked different so I made sure to get the new ones.
since you are buying used and putting them on a truck that didn't come with them from the factory you might need a rivnut kit.
A
Alfonso713v
I called the dealer and they said they only got 09-11 rams. The brackets are different
Kil1itwithfir3
Winchester VA
I'm going to knock the dust off this thread real quick. lol I'm going the opposite way, I have a 2010 and found a set from a 16/17 for sale. was there any confirmation of it actually fitting or did you have to make alterations?
