blackbetty14
- Oct 23, 2014
- 2,701
- 1,425
- CT
- 2024
- Hemi 5.7 VVT/Etorque
So guys… got a few complaints about not being able to see my black nerf bars on my blacked out express 14 ram CC. Mostly from my parents who can't see the bars getting out at night. So I figured out a way to light them up nicely (from a couple of threads on here). I just started tonight as Ive been waiting for the 20m spool of LED extending wire to arrive. For what its worth its about 20*F out laying in the snow to get this mocked up (1 side only for now).
What I got was two 15M spools of 5050 red LED 300LEDs off ebay for like $12 a pop or $25 total. I picked up a DEI 8600 micro magnetic switch (normally closed, so tail gate is down switch is closed, tailgate closed the switch is open) Cost me $10 shipped off ebay. I got 20M of LED extension wire or 28 gauge red/redblack 2 wire for $10 shipped.
For the Bed Im going to run 2 full 5'7" strips of red LEDs down each bed rail (underside) connected in series to a relay (maybe). The relay will get power from the 7 pin trailer wire (i think) might grab it from somewhere else well see. The Magnetic switch will trigger the relay and Im thinking I might add a manual switch in there in case i want the lights on but the tailgate closed.
I will be adding some red LED accents to my footwells with the left overs from all this as well as maybe some grill lighting
Now my running boards are 3" 304 SS black painted cheapo's off ebay, they are sturdy and I like that they stick out rather far compared to the stock types on all trucks which seem you can only get your toes on it. I cut a 80" length of red LEDs and cleaned and prepped the rocker for the adhesive to stick. ITs cold out remember so this was not fun lol. Before I mounted it I ran an extension wire behind the wheel well covers up to the riverside firewall and pushed it into the cabin via the small grommet that has the hood latch cable going through it. I then hooked it to the Footwell lighting plug on the underside of the steering column. So I unlock my truck and the side steps are illuminated, I lock the car and they slowly dim off with the interior lights. In the car when the interior lights are off and driving the red LEDs are off. I open the door to get out and they come on with the interior lights. Even when the truck is off… as long as the interior lights come on they will light up too. It makes a HUGE difference and really make the side steps noticeable… not to mention light up the ground pretty well too Im very pleased with them and they are pretty bright. They can be seen the farther you are from the truck as I angled the LEDs to face the steps for that main reason of lighting them up more than lighting up the ground like a under truck lighting kit.
The red is my theme for the truck with lighting as i also have red rear license plate lights. Looking to do red rocker lighting, red interior footwell lighting, red bed lighting and perhaps some behind red grill lighting.
here are some pics. Going to save a few thread spaces to update the thread as I progress!
Before lighting, very dark and hard to see even on a lit street. This is how the truck will look anytime the interior lights are not on.
Just a touch of the key to unlock the doors with the key Fob.
Same pic as above but they lighting seemed brighter… its very red and bright, camera doesn't do it justice. Im only putting it up bc its the same shot almost as the pic above and its visually brighter, but more bright in person.
This is how they look if you bend down or if your far enough away and can see the truck at a far enough angle (my least favorite obviously but nothing I can do).
How they look looking down if you were going to get in or out of the truck.
Just a quick pic to show how bright they are. This is just unlocking the doors with the key fob.
I def recommend the mod to anyone. Took me about 1hr to do one side as I was figuring out placement, how to run the wires, solder everything up and mount etc.
Future posts will show the rest of the rocker lighting, footwell, bed and grill lighting. stay tuned!!
Heres the Pass side all done!
Before lighting
After lighting
Found the nerf bar
back of the truck with red license plate lighting.
This is how easy it is to hook up, linterally just 2 wires, 12v+ and ground.
Video of lights working with Key Fob unlock/lock.
http://youtu.be/BtsEy8zC2vk
So apparently Photobucket wants me to spend $400 a year for photo hosting for these to work... not going to happen lol. So I'm posting a few pics of the bed and step lights.
Before lighting
After lighting
Found the nerf bar
