Nope. They have a shutter door in the projector which retains the high beam functionality.
Every connector I had on my truck plugged right into these headlights. Nothing extra, no splicing, no issues.
I'm assuming you had the dual headlights on your truck, not the quads?
Sent from my DROID RAZR using Tapatalk 4
A Longhorn is going to come with quad headlights, not duals.
Yea i figured as much... The only reason i ask is because i was looking up the eagle eye projectors on Ebay and couldn't find any compatible with quad lamps. Just wanted to know if a different wiring harness had to be used?
Quads and duals are swappable without ANY harness.
Here's why.....
Duals - H13 bulb. Truck's OEM harness is H13, plugs right in.
Quads - has a built in splitter from H13 --> H11/9005. H13 plugs right to the truck's harness.
