I hope this is the right area. Stock truck stock wheels and tire size. Ok so I just got a 2014 ram 1500 quad cab 5.7 2wd a few weeks ago. It has 77K on it and the previous owner (family member) had new tires put on it 1000 miles ago and it had some uneven tire wear on the inside of the front tires. They took it back to the dealer who installed the tires and did the alignment to double check the alignment. They said the alignment was good and to come back every 2 weeks to have the tires rotated so they would wear even. This sounds ******** to me. I will be having a friend double check the alignment next week when he is back from vacation (that's his specialty). Is this a common problem with these trucks or is there something I should look at?
Thanks,
Max
Thanks,
Max
