OEM SRT10 Rims
Deepc6
Long Island
Hemi 5.7 Etorque
Hello All,
I have the option of purchasing a set of OEM black powder coated SRT10 rim and tires locally. The question I have is will they fit my 2016 1500 without spacers? Do you think this $1500 is a good price for them, as they do not come with TPMS?2017b5a39b5cd3f70ac37b3f5121f254.jpg
quietpeen
2021 TRX
Hellcat
if you are 4 wheel drive you will definitely need 1/4" spacers, not sure for 2 wheel drive
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
I have a 4WD, will I need 1/4" spacers for all 4 wheels
quietpeen
2021 TRX
Hellcat
You will only "NEED" them for the fronts but why not make them even. I had srt 22's on my 05 with 305/45/22 and the tires rubbed the fender liners in the rear, but that was a solid rear axle so it might not happen on a 4th gen with independent rear suspension.
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
Thank you for your insight. I will not be using this truck off road mostly street and occasionally gravel and a boat ramp. Since I have 4 corner air ride suspension I cannot lower the truck to get it leveled. The truck already has the factory flares and I really do not want my tires to stick out past them. I do want a slightly larger rim and wider tire. The only reason I was going the OEM route for wheels is because I live in NY. The roads here especially after the winter are tough on wheels. I have not had the greatest of luck with replica wheels. If you know of some forged or polished wheel manufacturer you would recommend I am all ears.
quietpeen
2021 TRX
Hellcat
I can say that these will not still out past your fender flares so you are good there. Sorry but I don't have any recommendations for you.
BlownGP
Houston/Baton Rouge
Depending on what tire you go with, you should be fine.
The SRT10 wheels have a +25 offset so they will kinda be sitting like stock since they have a 10" width.
And $1500 is kinda high. The OEM wheels are forged but they are hard to find now days I guess. You getting the tires on them too?
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
I am fine with the ride height of the truck as mostly seeing the highway and street.
Ideally I am looking for a set of wheels which do not require spacers and I am planning on keeping stock rims and putting some winter tires for when I go to the cabin and skiing.
BlownGP
Houston/Baton Rouge
Yeah, well these will be fine then.
quietpeen
2021 TRX
Hellcat
Unless you get a 285 tire which will have a real small sidewall you will need 1/4" spacers.
If you got 10mm hubcentric spacers it's nothing to worry about. I ran the cheap autozone 1/4" spacers and had no issues
BlownGP
Houston/Baton Rouge
To clear the front?
He should be fine with a 305/40
285 is really to narrow for a 10" wide wheel anyways.
quietpeen
2021 TRX
Hellcat
With 4 wheel drive? I'm thinking it will rub...but might be real close if it doesnt
StoneDude76
West Chester,PA
I have 305/45/22 on repro SRTs and I rub the sway bar in reverse at full lock. No rubbing anywhere else. The tire does come close to the upper control arm but no rubbing. Yes my truck is a 4x4.
Sent from my VS985 4G using Tapatalk
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
Do you have spacers installed on your front wheels?
BlownGP
Houston/Baton Rouge
Good info.
Like I said will probably fine with 305/40s
I have 305/45/22 and there big tires.
