Opt-7 hid question
Mycyl
Ontario
Hi! I recently bought my first hid kit (opt7
55w bolt series with relay harness and resistors) and installed them into mmy storm projectors.
My question is, where do I install the resistors!?
So they go between the bulbs and the ballasts? The instructions are not the greatest...
any other tips? Has anyone used these?
trip1027
The good kits have them built in so couldn't tell you bud.... that's why opt7 I will not buy
SportyJames
Corpus Christi
2015 RAM 1500 Sport
I mounted mine up on the core/radiator support. They hang off so there is air flow underneath them. They get super hot.
M
Mycyl
Ontario
Sorry about the confusion, I meant to ask where do I install the inline capacitors?
iam_canadian22
northern ontario
The capacitors go between the trucks wire harness light bulb plug and the ballast or relay harness if your setup uses one.
