- Nov 15, 2016
- 1,026
- 833
- Central Virginia
- 2011 1500 Laramie CC
- 5.7L
I just installed the OPT7 bar last week.
I removed the plastic grommet around the tire access hole and installed the light bar so the bottom edge is on top of the spare access hole.
The light bar is still perfectly visible from the rear, it's just when you are up close looking down that the LEDs aren't directly visible.
The kit comes with clips if you want to drill and mount the clips. This makes the light bar easy to remove and you can mount it lower than I did. Perfectly happy with the location I used though.
