RamRod13
Hey guys,
I installed Opt 7 Flux Beam X LEDs in the low beams of my 2013 over the weekend. Have to say I am loving the light output of these versus the stock halogens. I am getting a lamp out message for the passenger side though. The message comes up 1-2 minutes after the truck is running and quickly disappears, not sure if it should stay up or not. Should I be concerned about this since everything appears to be working fine? I used all the adapters and capacitors that were sent with the lights. Any thoughts?
As a side note, part of my reason for doing this upgrade was because I was getting my moisture in my passenger headlight. I took the light out, let it air out, and resealed it hoping the moisture would stay out. Two days later I already have condensation inside the housing again. Looks like I will need to buy a replacement housing.
