swine
Today I started on my latest project, projector fogs. I have a 2015 1500 with the vertical fog lights. I'm currently running OPT7 LED's in them. I'm not terribly impressed with the range of the LED's, but I do like the color output. I'm also not thrilled with the chrome reflectors sticking out like a sore thumb against my black bumper.
I figured if I did a projector retrofit I could not only totally black out the lights, but also increase the output. So I bought a new set of TYC fog lights and proceeded to baked them open. It was easier than I thought.
I followed the method I saw on some of the Retrofit Source videos. I put them in a pre-heated oven at 270 F for 7 minutes. I had to do this twice as I was only able to pry about half the lens off per time. The adhesive loses it's pliability really quick. I took my time and was fairly gentle which probably accounts for having to heat them twice, but I didn't want to force the lens off and break or warp anything.
Honestly, it took longer to remove the old adhesive than it did to open the lights. I would just keep alternating popping them in the oven for a few minutes to soften it up and then work until it started to get hard again.
My plan is to fit Morimoto Matchbox projectors. It looks way simpler than trying to cram the MH1's in there. There doesn't seems to be enough room for the MH1's without some significant cutting. According to the specs the Matchbox projectors require a housing depth of 80mm as opposed to the MH1 needing 115mm. It looks like the fog light housing can handle between 90-100mm max without opening up the back and I'm not sure I want to get into that on my first attempt.
I still need to order the supplies to finish the lights. I didn't want to order anything until I figured out if I could successfully open the lights. Once I get all the parts I'll be painting everything black (reflectors and shrouds). I'm also gonna fit the projectors with switchback halo's. I've seen others with blacked out projector fogs and really liked the look. I think they'll blend in quite nicely with my black bumper.
I'll update as the project progresses.
