Projector Fog Light Retrofit
JPT
NY
2015 Big Horn
Over my past two trucks I have spend about $2k on lighting. I wouldn't spend this kind of cash on fog lights, but driving lights are very important to me. After I got my Audi, I knew I could never go back to halogen.
I think seeing WAY better, and not blinding people is worth the investment.
I personally do not think that fog lights really warrant this kind of cost, but appreciate the time and effort of the OP and others to improve their look.
Also, if you put on light bars here in LI, you are very likely to get pulled over. Especially if you have your fogs on as you have passed the legal number of driving lights.
swine
swine
NE Indiana
And my kenwood radio i had, the screen cracked. I need a radio with gps. Factory 8.4 is over $1500 new, so i would say i got a great deal on a lit betyer of a radio than the 8.4
That's not the point. I don't really care what your reasons were, the fact is you decided to upgrade something on YOUR truck to meet YOUR needs and wants. Good for you, but I didn't go on YOUR thread and dump on you for what YOU chose to spend YOUR money on.
2010 Infantry Vet
Butler pennsylvania
Wow calm down guy. I was just wondering how the $500 fog light upgrade compares to LED fog light bulbs.
TRXHemi
Sugar Land, TX
Those look great. You put in a lot of time and effort, and the end results show that! It really looks nice.
swine
swine
NE Indiana
I cant seem to understand how you guys can justify spending almost $500 on upgrading foglights, and $1,000. On headlights. Thats insane!
If you need extra light, just add a $100 lightbar in the bottom of your bumper!
Nowhere in that first quote is there a question, just a snarky comment criticizing something I chose to do with MY truck and MY money. Why do I have to justify how and what I spend MY money on? How is that wondering how the lights compare? If YOU don't understand it, that's fine but you don't need to ridicule others because you don't like their choices. And I'm plenty calm, but I've noticed that you seem to like to stir up trouble all over the forum with your opinionated ignorant comments. I'm done, go back under your bridge.
2010 Infantry Vet
Butler pennsylvania
Wow. Sorry you feel that way. Have a nice day
WilliamS
Tampa FL
I know I’ve asked already but still curious to what these look like from the back to protect the bulb or projector from water intrusion?
I have the morimoto led fogs but I want more throw so now it’s time for some projector fogs.
swine
swine
NE Indiana
There's a silicone seal where the shaft of the projector extends through the housing. The bulbs themselves fit tightly into the projector housing. I've never had any issue with water intrusion. I don't really have any pics of the back of them installed.
WilliamS
Tampa FL
Cool, as soon as find some me to swap me the morimotos for some stockers I’ll start.
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
What year is your truck and what do they look like?
QwikKota
5.7L
The new fogs look awesome and are super bright. Does anyone know a cheap way to make the OEM fogs match the color range of the headlights? My fogs are very yellow. I have a Laramie, I think the headlights are projector style which is a question when searching for fog lights for some reason. I am just looking for some swap in replacements more of a white color.
WilliamS
Tampa FL
99% of the LED on the market will be close to the color temp. Look for something in the 5500-6500 range and it will match up. Although the headlight bulb is likely hologen meaning it should be in the 4300 temp range, the projector alters the color a bit.
brianw0048
EcoDiesel
So you get any bounce from the projectors in the fogs?
guntisp
Latvia
[QUOTE =
I had some issues with the wiring of the halos on the front turn signal circuit. Seems the truck didn't like that for some reason. Worked fine while I was testing it, but as soon as I started the truck the front signals wouldn't work. I'm going to connect them to the trailer circuit since that worked fine when I tried it (running).
I'll see if I can get some output pics tonight.[/QUOTE]
I have a problem with halo. Nothing happens when the turn signal is turned on.
Profile Pixel driver + Morimoto controller.
I connect the Halo 5 pin cable to the driver (white - white). I connect the 5-pin driver cable to the controller (black-black). I connected the driver's orange wire to the 12 pin pin turn. I connected the black wire of the driver to the car ground bolt.
I connected the controller red wire to Fuse 99, the controller black wire to the car ground screw.
What am I doing wrong?
guntisp
Latvia
I found a problem. Wire connector at fault.
