Oops sorry guys for some reason I didn't get any notifications on this thread! I have not seen clear lenses yet for these. With some body work you could certainly pop out the lights and do away with them or try to retrofit in some white markers. I wasn't too sure how I felt about the amber markers at first but now I love them.
My build thread has some detailed photos on the grill as well as a lot of explanation on it. BUT to help out
here are some details of the trim work that helps to blend the 42 inch curved lightbar into the grill. I designed the trim pieces to fit the curve of the grill and the lightbar, as well as fit the overall profile of the existing trim on the grill and then 3D printed it.
This post has a few detailed photos of how I mounted the lightbar. The lightbar is mounted directly to the grll in order to simplify things, finding somewhere to mount the lightbar with the active shutters was looking like a lot of bending in order to avoid just blatantly drilling into the truck. I used some simple flat aluminum that I bent into 2 90 degree brackets. It is riveted directly to the outer bezel of the grill and holds the lightbar very nicely. Allows for a small amount of play but at the same time is solid.
