In my fuse box that position has a fuse in it. What's strange is that in JJs pic there is the wire for the halos, then a yellow fuse to its right and then another yellow fuse to the right of that one. The halo wire is pushed into a single terminal (a fuse is pushed into two terminals). My fuses go, yellow fuse, single terminal open then another yellow fuse. My open position is in between the two fuses not to the left of the fuses. Hope that makes sense. Not sure if that guy moved the fuse over one for better fitment of the wire or if that's how his box is set up.
