Recon Smoked 3rd brake light?
ltr450rider13
Got recon 3rd brake and cab's for 100 new in sealed boxes gotta love CL. Only thing is the 3rd brake light seems to stay lit very dim, even with truck off. Anyone have this problem?
highwayman1224
Goodyear, Az
Mine does the same thing, very annoying! It goes out after I shut off the truck though, but it takes a little while to go out.
ltr450rider13
How long u ******? Should I be concerned bout it runnin down battery? My cab lights, license plate, LEDs doesn't do. Why would just red brake LEDs?
ltr450rider13
Odd. Thanks highway. Recon said to put load resistor on it. That shouldn't be needed. Says plug and play.
G_Altima
Kaukauna, WI
Just installed my Recon lights. I love the look of them and everything seems to be working correctly. I did have the LED reverse lights in backwards so neither of them worked but have it all straight now.
G_Altima
Kaukauna, WI
Well i guess i was wrong about my 3rd brake light. The cargo light does stay on dim while driving. Recon said to get a 6 ohm - 50 watt resistor which i got off of ebay for next to nothing. Wired one end up to the positive wire of the cargo light and the other end i grounded to the body inside the brake light cavity. It got up to 32 degrees here today so i finally got around to tackling this project. The positive wire for my cargo light was the white wire on the brake light which plugs into the white wire with a tan colored stripe from the truck. All is good now. Used some silicone and mounted the resistor out of the way in the top of the cavity. Hope this helps anyone who is having this problem.
