TXPudge1868
Howdy,
As the title says, I'm stuck between the Ridge Grapps and BFG KO2s. I've finally decided on Method Standard 17x9 -12 since I think they look the best with the prerunner look I'll be going for (minus the expensive flares and suspension work). I'll be staying in the 34" tire range since I can't decide between the Nitto's in LT305/70/17 (33.9"x12.2") or the KO2s in LT315/70/17 (34.4"x12.4").
I originally thought that the KO2s were going to be a few hundred more than the Ridge Grapps, but they're almost identical on the sites I've been to (Discount Tire, DT Direct, and Custom Wheel Offset) with the Nittos actually being the more expensive route in most cases.
I like the tread design on both tires, but I do like how the BFG's will stick out just a tad more in comparison to the Nittos. I know that the Nitto's are obviously a newer tire, but which direction would y'all go if you were in my shoes?
Thanks for the help,
Tanner
Tanner
