rim 15 on our trucks
california
who on here has done the 15" wheels on our ram trucks??
picture will help alot thinking of going that route?
what exactly do you need for the conversion to make it work 100?
california
california
15" rim conversion
charonblk07
Calgary, Ab
F1-A forged 349ci
You need the SSBC disk brake conversion from a 2nd gen 1500 with the Chrysler 9.25" rear axle. It will bolt right to the axle housing and you will lose the e-brake in most cases.
autos221
Long Island, NY
Won't work I have tried, 17inch is the smallest you can go before you hit the caliper
california
california
your wrong it will work with some modification but want to know how excatly to do it before pulling the trigger
california
california
any modifications
BlownGP
Houston/Baton Rouge
Well if you know it takes some modification, shouldn't you know what that modification is?
anything below 17s with not fit on the front. Calipers are too big.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I believe he is saying to install smaller rotors and calipers ofg a older 2wd so they will clear.
charonblk07
Calgary, Ab
F1-A forged 349ci
Here's from Matt's thread on the conversion
I bought an SSBC rear disc conversion for the 2nd gen Ram trucks. Its not completely bolt on, but it looks like it will be easy to modify. I'm going to have to drill new holes in the caliper mounting brackets for the speed sensors, have to extend the rear brake lines, and also get rid of the emergency brake.
Wandell
Cummins 6.7
Why would you want to mount 15 inch wheels on a 4th gen?
charonblk07
Calgary, Ab
F1-A forged 349ci
This is a drag racing mod; the tallest drag slick/radial you can get is 28" and they're expensive. 15" wheels have a TON of options in both slicks and radials and they're about 1/2 the cost. I can also get a 30"-31" drag slick/radial which better matches my 4.56 gears and I don't run out of rpm like with the 28".
california
california
yes and no i know u need modifications because ive heard and matt from moes has done this to i believe but i dont exactly know what you need to make it work 100percent beside the brake kit ....
