Rim Offset
daveray9
I have a 2012 w/ chrome clad and am looking to buy the RIMs from the newer 4th gen Rams that are blacked out, but I am reading they are 18mm offset and mine is 19mm.
I have new BFGoodrich KO2s installed and would want to keep these, they are stock size of 275/60/20. Does the offset matter or change the tire size by 1mm?
A05GSHO
Southeast WI
Your tires on the 18mm will be just fine, only a 1mm difference.
Maligator
Hem 5.7
You probably wouldn't even notice a 1mm difference. FOR example my fuels are a 0 (zero) offset and stick out from my fender about 3/4" of an inch.
So the difference between +18 and +19 would mean the wheel would be offset 1mm further toward the center of the truck. So basically a hair over 1/32" of an inch.
daveray9
daveray9
Thanks guys. Figured as much just wanted some feedback.
quietpeen
2021 TRX
Hellcat
the offset is not 18 mm on the 20x9 black sport wheels its 19.05mm
quietpeen
2021 TRX
Hellcat
Ouch! Now that makes it more difficult. :)
lol, yea its not much of a difference but the o.p. was questioning it and 18mm offset isn't correct
