Rim offset
derek666
I'm looking at getting new rims for my truck. I'm gunna stay with the same size tire but with a negative offset rim. I would like it to stick out atleast an inch.
The truck is a 2013 ram sport. Tire size is 275/60/20.
Sent from my SM-G920W8 using Tapatalk
quietpeen
2021 TRX
Hellcat
20x10 with -24 mm offset will stick out more than an inch. With A 20x9 with -12 mm offset the face of the wheel will be 1.25" out further than stock
D
derek666
If I went with a 20x9 with a zero offset how much would it stick out
quietpeen
2021 TRX
Hellcat
3/4" further out than stock 20x9 wheels with 19mm offset
D
derek666
Is there a conversion chart or you just have this knowledge in your head
quietpeen
2021 TRX
Hellcat
there are conversion charts, but what i gave you I for the most part had in my head and just checked the math
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
A 20x9 0 offset will stick out 3/4" further than where your stock wheel/tire is sitting. Realistically that should be about 0.5" past your fender. If you want 1" past your fender then you'd want to go with the 20x9 -12 offset as quietpeen stated above.
EDIT: quietpeen beat me to it ;)
D
derek666
Perfect. Thanks a lot for the help
14blackouthemi
North Jersey
Aren't stock sport wheels 20x9 with like +18 offset? Here is my old truck 12 sport with 20x10 -24 offset. With 33x12.50 tires. 2750ebb0d29e37da37e8f789514785b1.jpg
quietpeen
2021 TRX
Hellcat
Stuck out about an inch or a touch more.
that's weird.
here is mine with 20x10 -24 mm offset and 33x12.5x20 tires and they definitely stick out further than an inch....the tire is close to 3" out
here is a shot with fender flares which give 1.5" of coverage roughly
VB712
Maxi_built
Va Beach
that's weird.
That's perfect leveled or factory front height? Any rubbing?
quietpeen
2021 TRX
Hellcat
Bilstein 5100 adjustables set at 2.1 with no rubbing. There was rubbing before I installed the bilsteins
D
derek666
Exactly the amount I'm wanting them to stick out. But it seems every rim I look at they don't make the rim with more then a 0 offset
brandonjansen
What wheels are you looking at. Some definitely are limited in options for width and offset but there may be some alternatives that we can recommend.
D
derek666
I'm looking at moto metal mo962. I might just get the 0 offset with wheel spacers
brandonjansen
I would personally recommend getting the correct offset and avoiding spacers if you can. Some alternatives you could look at are Fuel Mavericks, Gear Alloy Big Blocks, or Ballistic 959 Rage. All have a similar design to the Moto Metals.
Kid's HEMI! !!
20x10 -24 but I have maxtrac spindle pushes it out an inch
[/URL][/IMG]
[/URL][/IMG]
1Popeye
