side step / running board FAIL!
wildkarde
NYC
so this happened today... i guess being 250pds isn't the prescribed weight limit for daily use on these oem steps. :banghead:
I've seen some other options. And I've noticed the 2013+ OEM steps either mount at either end of the body or have 2 separate steps for front and rear.
I'm sure I can either have a reinforcing plate welded over the hangers and holes and remount these but what other options does anyone suggest? Because I only want to fix this once if possible.
I ran without steps for a while but the 6" lift on 37s tends to make getting in and out a chore. Plus if I remove them from the passenger side I have to extend chivalry to EVERYONE and who has time for that :roflsquared:
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Yeah, not a fan of the rivnut design and how these steps attached.
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
If this is OEM then you should be under warranty. Unless you added them and the truck didnt come with them.
wildkarde
wildkarde
NYC
It's a '12. My full warranty ended last 2015. Just power train active now. But I'll check.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Take a plate prob 3/16" thick cut into squares the same size as the clean area. Then drill holes in pattern of bolts on steps for bolts, insert bolts through the plate so they poke out and towards the driveshaft and weld heads to the plate. Remove/cut/ drill existing bolts in step brackets, drill holes so step bracket slips over bolts. Attach with thick washers, lock washers and nuts. That's one way.
Another is to do same thing but weld nuts onto 3/16 plate and use new bolts to attach steps. Or if the metal is thick enough, drill and tap for studs and attach that way. Would be a hell of a lot stronger than the OEM thin steel.
Wow my $115 aftermarket steps attach better than those.
derag2
6.4 hemi
Look up ici magnum rt steps... Email them and ask them for 6 of there triple t mounts for the steps... That will take care of it... I'll try and get a pic for you tomorrow when installing my steps what I'm talking about.
ICEChargerRT
Florida
That's scary. I'm about the same weight as you and recently installed the OEM boards on my truck.
avolnek
2015 Ram 2500 CCLB
I went with Tough Country steps for this exact reason. the factory and many other makers mount these damn steps to the body... Tough country has the old solid style of bolting in with the body mounts... mounting to the frame is the only smart way so i am unsure why they are using the body...
SportyJames
Corpus Christi
2015 RAM 1500 Sport
I put the AMP power steps on mine. I will never go back to the conventional steps you can see again.
But, like the OPs falling off, I have to deal with a motor fail possibly.
derag2
6.4 hemi
You put it in behind the sheet metal. Top bolts sticks out for a but and your bottom holes line up with the bottom holes that your nutserts ripped out of... Now the only way It's comming off is to rip the whole chunk of metal off.
BigA
Ohio
5.7 Hemi Etorque
Ooch, I only step on mine to clean the roof and I'm about 290lbs. I guess I won't do that anymore.
bigolayne
Springfield, MA
It's sad that almost all of the steps are attached at the rocker. I've been looking and found some universal rock sliders that attach to the frame.
In the Spring the rock sliders are going on and they are meant to support the weight of the truck and also allows for a highboy jack.
derag2
6.4 hemi
Here's another picture of the bracket behind the metal.... It would be much better set up than the factory......
But I will say it would be nice if they all would mount to the frame, but if you do body lifts them you steps will stay in the same spot... With the body mount the steps are were they belong no matter what lifts you do.
gofishn
Iowa
hemi 5.7L, 345 cu in
known issue. If your boards are recently installe,d pick up teh amp research backing plate, then reinstall boards suung it. helps to spread otu teh weight acvorss more metal
oops, just say above postings. Pretty much same thing as AMp Research brackets.
works better than welding a plate acct welding weakens teh metal and surface area, across which the weight is spread, is not as much vs goign with backing brackets.
luck to you
SportyJames
Corpus Christi
2015 RAM 1500 Sport
luck to you
Dad is that you? Looks like one of my Dad's texts. LOL.
wildkarde
wildkarde
NYC
If the truck wasnt lifted 6" I probably wouldnt use it either but alas that's a big step up with no step LOL
Where does that bolt that sticks out go? thru the top where the step hangs?
luck to you
thanks gofishin. those brackets look simple as well.
one of these solutions gotta work. the weld or the behind the metal hangers from ici.
wildkarde
wildkarde
NYC
I might have to give them a call. They dont have any local dealers though so shipping would be a big factor. Frame mounting looks nice and safe, was just trying to avoid buying a whole new step package.
blackbetty14
CT
My cheap $118 black SS steps off eBay mount to the body and brace/support off the body mounts. I'm like 210lbs and they work great.
