Is chrome part on the stock rims on a 15 bighorn really just a plastic hubcap?
This is my third vehicle with them. They are easy to clean and don't pit like chrome wheels ,or have the clear coat peel like they do in aluminum wheels. My neghibor has a 2005 and they still look good. They are bonded on the wheel and don't come off. And really they must look pretty damn good if it takes some people months to figure it out.
I had a 1995 F-150 that had the chromed plastic covers. They are easily cleaned, aren't going to rust/pit and much less expensive to replace. I believe that the skins on my Ford were replaceable though. I like them, they don't bother me any.They are not hubcaps. They are not removable. They are securely epoxied to the rim. Anyone complaining about them has not had the price ledge of spending big bucks on a nice set of Cragars only to have them destroyed in short order due to salt and sand. Ahhh the good old days... NOT
I'll take the chromed plastic thank you.
What specifically do you use to clean them? I use "wheel cleaner" but still seem to have residue on them.
The cover will come off seen a couple post about it.
but like was said they dont rust.
It has to be pulled off, it's bonded and not like a hubcap.
Mild soap and water is best....Don't use wheel cleaner products as they can damage the finish. Wiped clean very easy...I often just wipe them with a dry towel.
I can't seem to get this off...
Yes just like i said they will come off.
