LED bulbs suppose to live much longer and are even brighter, but the problem is the dust cap of the quad headlights making the installation complicated.
It is possible to install some of them inside the housing with the dust cap on,
but this may lead to a overheating problem as the air space inside the headlight housing is small.
LED's are very sturdy bulbs, but the only thing killing them fast or reducing their lifespan is heat.
Long-Term first hand experience of the users here will show ow long they really last!
Everybody here is using cheap LED bars or ultrabright blue bulbs dazzeling terribly the opposite traffic, and i don't wanna be one of them.
Chris
Not true. I have the OPT-7 FluxBeam-X H11 Low Beams and they are super bright and fit perfectly inside the quads lowbeam. See my pictures below of them installed on my Quad headlights.
I didn't see what year your truck is, but the OPT7 LED's will fit inside the quad housings with the dust caps. There are a couple members on here that are going on 2 yrs with them and haven't had any issues. The newer version - Fluxbeam X - are supposed to be smaller, yet brighter, with better cooling setups.
I have the Opt-7 FluxBeam-X LED H11's in my current set of lights, a custom built set of Quads.
They are insanely bright and the beam pattern is amazing. They don't blind oncoming traffic, and they are SUPER bright!
Yes the LED's fan is close to the dust cap but it's not going to hurt the bulb. They still get plenty of air.
If you look at the picture of the lights against the wall, you will notice how they are very focused and clean. They don't "scatter" and throw light everywhere. Now, the cutoff isn't anywhere close to being as clean as an hid in a projector, but for an LED Bulb in a halogen housing, the cutoff on the light is really sharp and nice.
Also in the picture from the drivers seat you can see how the bulbs don't throw light everywhere up into the trees or grass on the sides of the road. Again, they are focused and centered.
As for longevity, the bulbs are rated for 50,000 hours. I have not had one issue with them yet and the Opt-7 2 year warranty will send you 2 replacement bulbs and 1 replacement Driver, for free, if anything goes bad. That's a decent warranty.
I highly recommend the Opt-7 FluxBeam-X LED Bulbs to anyone with a Dodge Ram and Quad Style headlights who doesn't want to go HID's.
The key to not blinding oncoming traffic and getting them to shine like mine, is properly adjusting the headlight housing and making sure the LED Bulb is seated and aligned properly inside the housing!! The bulbs have a L and an R on them. You need to make sure they are put in the right way or the light output will suck and you will blind other drivers.
Sent from hell via TapATalk
