Tire Chains for 2017 RAM 1500
seca2man
Norcal
Hello folks. First time RAM 1500 owner (Big Horn 4x2) and got a question about tire chains. The truck came with 275/60-20 tires, but the owners manual only says use Class S chains for a smaller tire like 265/55-17. Seems kinda strange that RAM doesn't mention possible chains for the larger and wider tires that came with my truck. Been looking around several chain websites and have found a few who claim to be Class S and also fit my exact tire size. I'm used to putting on cable chains for another car. I think the issue is clearance with brake lines behind the RAM rear wheels.
So is it safe to put on chains that are advertised as Class S and fit my tire size? Anyone have any experience with this? Thanks!
kooler1
I’d use the cables instead of chains. Not sure about the class s for cables.
2012 ram 2500 4x4. 3” lift. 37x13.5x17 toyo mt. Smitty built grill, kenwood radio, bullet liner.
jasonw
South Dakota
5.7L Hemi V8
I am with kooler. I'd run cables. In my opinion, there isn't enough clearance with the 20" tires on a 1500 for proper, good chains.
I bought a set designed for my slightly larger-than-stock tires, but these are the equivalent for your tire size:
https://www.amazon.com/dp/B000HZFDSC
They also make these, which appear to be a little more durable but a little harder to put on:
https://www.amazon.com/dp/B001H9GRD2
