Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Exterior
Exterior
Tire Conversion Chart.
This is a discussion on Tire Conversion Chart. within the Exterior forums, part of the 4th Gen : 2009 - Present category!
i hope this helps! 225/85R 14 = 29 X 9.00 X 14 215/75R 15 = 28 X 8.50 X 15 ...
Like Tree9Likes
Sponsored By: BAK Factory Outlet
Reply
Old 07-16-2010, 11:20 AM   #1 (permalink)
powerhour's Avatar
Ram Year: 2014
Engine: 3.6
Default Tire Conversion Chart.
i hope this helps!
215/85R 15 = 29 X 8.50 X 15
225/75R 15 = 28 X 9 X 15
235/75R 15 = 29 X 9 X 15
325/60R 15 = 31 X 12.50 X 15
Q78-15 = 35.50 X 11.00 X 15
215/70R 16 = 28 X 8.50 X 16
225/70R 16 = 28.50 X 9 X 16
225/75R 16 = 30 X 9 X 16
235/70R 16 = 29 X 9.50 X 16
235/85R 16 = 32 X 9.50 X 16
245/70R 16 = 30 X 10 X 16
245/75R 16 = 31 X 10 X 16
255/70R 16 = 30 X 10.50 X 16
255/85R 16 = 33 X 10.50 X 16
265/70R 16 = 31 X 10.50 X 16
265/75R 16 = 32 X 10.50 X 16
265/80R 16 = 32.50 X 10.00 X 16
275/70R 16 = 31.50 X 11 X 16
285/75R 16 = 33 X 11.50 X 16
295/75R 16 = 33.50 X 12 X 16
305/70R 16 = 33 X 12.50 X 16
305/85R 16 = 36 X 11.50 X 16
315/75R 16 = 35 X 12.50 X 16
325/70R 16 = 34 X 13 X 16
325/80R 16 = 37 X 13 X 16
365/65R 16 = 35 X 14.50 X 16
Q78-16 = 35.50 X 11.00 X 16
265/70R 17 = 32 X 11.50 X 17
275/70R 17 = 32.50 X 11.00 X 17
285/70R 17 = 33 X 11.50 X 17
295/70R 17 = 33 X 12.0 X 17
305/70R 17 = 34 X 12.00 X 17
315/70R 17 = 34.50 X 12 X 17
255/55R 18 = 29 X 10.50 X 18
285/60R 18 = 32 X 11 X 18
285/65R 18 = 33 X 11.50 X 18
325/60R 18 = 33 X 13 X 18
325/65R 18 = 35 X 13 X 18
355/65R 18 = 37 X 14 X 18
305/50R 20 = 32 X 12.50 X 20
305/55R 20 = 33 X 12.50 X 20
325/60R 20 = 35 X 13.00 X 20
355/60R20 = 36.50 X 14.00 X 20
325/50R22 = 35 X 13.00 X 22
Sponsored Ad
Register to remove this ad.
__________________
Current.2014 Ram 1500 3.6L,1988 D250 S/C L/B 360
06 Black Ram 1500 MegaCab 5.7L.
07 Ram 3500 5.9L CTD, MEGACAB SLT.
Red Truck Club #3
R.I.P. 2005 Ram 1500 5.7 HEMI, Quad cab, 4x4 SLT
powerhour is offline   Reply With Quote
Old 07-16-2010, 01:29 PM   #2 (permalink)
glass3222's Avatar
Ram Year: 2005
Engine: 5.7 Hemi
Default
Good info.
Or if you want to convert it yourself:
1. take the first number (the width in millimeters) and divide by 25.4, this give you the width in inches
2. multiply be the second number (aspect ratio) divide by 100 (percentage), this gives you the sidewall height
3. multiply by 2, the add the 3rd number (wheel diameter)
Example: 275/60 R20 (factory 20" Ram tires)
1. 275/25.4= 10.82677 inches
2. 10.82677*60/100 or 10.82677/.6 = 6.496 inches
3. 6.496*2 = 12.992 + 20 = 32.992 = 33" tire height.
Babilon305 likes this.
__________________
Gone but not forgotten: 2005 1500 4x4 SLT Sport, 5.7 Hemi
2007 Dodge Durango SLT AWD 4.7, Superchips, BFG Rugged Terrains
glass3222 is offline   Reply With Quote
Old 07-16-2010, 01:48 PM   #3 (permalink)
Deviate's Avatar
Ram Year: 2005 4x2
Engine: 4.7
Default
That chart and formula will get you in the ballpark, but depending on the manufacturer the actual tire height will vary because of tread pattern or what have you. Case in point:
265-70-17 AT tires:
Formula Height: 31.61
Nitto Terra Grappler actual height: 31.57
BFG AT: 31.8
Dick Cepek Radial F-C II: 31.7
Not that a 10th of an inch makes that much real world difference, but just pointing that out.
__________________
"First it's pretty tires, then it's pretty guns...next thing you know, you're shavin' your beard and wearin' capri pants." - Si Robertson
2005 Ram 1500 Quad cab; 2WD; 4.7L; 2.5" level; Nitto Terra Grapplers - 305/70/17; Rancho RS5000 shocks; Hella 500FF behind the grill; De-Badged
Deviate is offline   Reply With Quote
Old 07-16-2010, 11:02 PM   #4 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
good info fellas .. stickie time
ramhunter9 is offline   Reply With Quote
Old 07-30-2010, 09:29 AM   #5 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
this is good to have also ...
Metric Tire Conversion Chart
Old 03-24-2012, 07:59 AM   #6 (permalink)
Ram Year: 2012
Engine: 5.7 Hemi
Default
Here's a handy calculator I've been using for years, it has a nice feature of showing you size differences as well!!
Tire size calculator
StLucieHemi is offline   Reply With Quote
Old 03-24-2012, 09:55 AM   #7 (permalink)
Stangshcky12's Avatar
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
I used that calculated till I found this one, extremely handy!
Tire Size Calculator - tire & wheel plus sizing
It tells you what the original tire by vehicle and allows you to compare to different sizes and tells you the %differences
TravisM likes this.
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Stangshcky12 is offline   Reply With Quote
Old 11-19-2013, 06:34 AM   #8 (permalink)
usmc1217's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Tire Size Conversion
usmc1217 is offline   Reply With Quote
Old 04-06-2014, 02:08 PM   #9 (permalink)
Birddog's Avatar
Ram Year: 2016 Bright White 3500 Laramie 4X4 Long Bed
Engine: 6.7 Cummins TD, 3.73
Default
Originally Posted by powerhour View Post
i hope this helps!
Great post. That's a lot of typing!
Sent from my Note 3 using Tapatalk Pro!
R.L.K. likes this.
__________________
Bak RevolutionX2 Tonneau, Amp Resch Bed Step
Clubs: WhiteTruck#62, 4X4#12, CTD#32, LowMiles#23, AftrDrk#54, Tattoo#38, ChopShop#11, Supporting Mebr#53, RF Hunt, Gun, Military, Motorcycle
Birddog is offline   Reply With Quote
Old 07-28-2015, 08:44 PM   #10 (permalink)
2012Outdoorsman5.7's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
I keep trying to figure out for the tires im planning on buying but dosent seem right, Let me know what you guys get.
285/65/20
295/65/20
Thanks.
2012Outdoorsman5.7 is offline   Reply With Quote
Reply
Tags
conversion chart, dodge ram 2500, tire conversion
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tire Conversion Chart. powerhour Exterior 7 03-13-2015 10:54 AM
Wheel and tire FAQ ramhunter9 Exterior 3 05-25-2012 10:06 PM
Wheel and tire ...FAQ ramhunter9 Exterior 3 05-25-2012 10:06 PM
Wheel and tire ...FAQ ramhunter9 Exterior 4 05-25-2012 10:06 PM
More Tire Shredding AF_Hemi Photos & Videos 15 07-07-2010 09:39 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
