rcb
- Feb 26, 2017
- 5
- 0
- 2011 Outdoorsman 2500
- 5.7
Fellas,
I have an '11 outdoorsman with the Rugged Trail TA tires. Max cold PSI on the tires says 80PSI. On the door sticker it tells me to run the fronts at 60 and the rear at 70PSI. I am not sure why I would run the tires different and why I would run the front so low. Do you run your tires at the recommended 60 front and 70 rear?
The truck is used for long drives while camping but only pulling a pop up, so def not a heavy hauler.
