I posted a while back about a problem with my 2013 Ram 1500. It's has a 4 or 6 inch RCX lift. 35-12.50x20s. As stated last time the TPMS wanted 40 pound in each tire which made it ride rough and the worst part when going into a turn the front tires would squall like they are scooting. Several members here recommended to lower the pressure in the tires and I did and I thought it fixed it. I only drive it on the weekends. I went yesterday and the tires squalled and pushed in every turn. I came down a hill on the approach to a bridge and you know how there is always a dip right where the bridge and the road meet? Well the front end scooted about a foot to the right at 60 mph. I stopped at the tire shop and had them check everything and adjust the alignment. They couldn't find any obvious problems and said it was out of line pretty bad. I thought there is the problem. Wrong. Done it all the way home. Went to town today and done it in every turn. Went through a long dip like a roller coaster dip that's down and straight back up and in the very bottom of the dip when the truck squatted a little bit, both front tires were screaming. I'm at my wit's end here. Tires are wearing even, drives down the interstate like a car. Just stay off the the dips and the turns. Hard to do when you live in the mountains. Any more help would be appreciated. Thanks in advance.
