- Nov 15, 2016
- 1,026
- 833
- Central Virginia
- 2011 1500 Laramie CC
- 5.7L
2nd two pics fully deployed...lol
Don't quote me on exact numbers but the stock mirrors stick out about 14.3 inches, tow mirrors down 16.3 inches and tow mirrors up 19 or so inches.
The mirrors up don't really bother me like it does some guys....long ago I had an F250 with the oem mirrors and they were the tall/tow type so I guess I just don't see why dudes bash on the ram tow mirrors.
Pic of said F250 for the Ford fans....
Nice! Yeah, they don't bother me either. I figure saying something prevents the comments that usually follow. Ha
Good deal....Someone else may have reg cab pics, or try Google image search.Thanks, I was just looking for this info!!!!
Anyone got a picture of tow mirrors on a regular cab??? Another quick question, are the wire connectors right inside behind the black piece or do you have to pull the door panel to plug in???
Any tips on wiring for running lights? I have the same set and plan to do this eventually. They are a nice aftermarket mirror.I purchased a set of EECCP tow mirrors off amazon for 200 dollars, i was very nervous the wouldn't have the ambient temp sensor but they did, they fit perfect and install took 15 mins each. Only thing I had to do the inside mounting bolt stuck out a little to much so I trimmed it. Great mirrors,
I actually wired my mirrors up as clearence lights instead of having the truck flashed for blinker signals, personal preference. Looks really cool at night they come on with my head lights.
Biggest issue I had, and once I figured it out it was very easy, running the wire through the door jam there is a plug you have to run the wire you use through not around.
Sure, Here's a link to all of the different tow mirrors that we carry for your truck. We have them that add power fold too!
If you have any questions, I can answer them for you. Thanks for checking us out.
Tony
2009 Dodge Ram 1500 Truck Mirror
Do you have any for a 2015 Ram 1500 express that would work. I like the puddle lights and the directional. My truck only came with heating feature manual fold away. How hard would a swap be
What are ALL of the options that your mirrors came with from the factory such as power, heat, memory, puddle lights, turn signals ETC
Thanks for asking,
Tony
Heated and power.
I do not have power fold away. Or puddle lights or turn signal. All I can do is turn the heat on and adjust the mirror from inside.
These tow mirrors would be a direct replacement for you, but I'm out of stock until
2015 Ram 1500 Truck Power Heated Textured Black Tow Mirror Pair
I just ordered a pair of your tow mirrors last night can't wait to receive them!!! Will post photos after I receive them.
