tpms how low can you go?
bighorn2500
2015 2500 ram bighorn
6.4 hemi
How low can you go before those low pressure sensors come on ?theres 95 pounds of air in my back tires, im looking for a better ride.
ohiogrown
ohio
2010 CCSB, 2011 ccsb, 2012 5500, 2016 5500, 2017 ccsb wxpress
4.7, 4.7, 6.7, 6.7, 5.7
Why the hell would you have 95 pounds in your tires??? A 2500 runs an LT which are 80 MAX. If you're not hauling I would run them at 65 to 70. 20% is the lower threshold for a tpms sensor, so if it wants 80x.2=16. At 64lbs your light should come on. Run just above that and you should be ok. And for god sakes don't run 95. That's tire scalping, ill handling, kidney jarring madness.
bighorn2500
bighorn2500
6.4 hemi
Thats what waa in them when i got it.
ohiogrown
ohio
That's got to be a brutal ride. Have you checked your door sticker? My guess would be it wants a staggered 65/80 or 70/80 front and rear. I'm not a big fan of that, we usually run them the same all around. But yeah, let those babies down. You'll be much happier.
NewBlackDak
Hemi 6.4L
65 cold before it complains. I run 65 all around unless I'm towing.
bighorn2500
bighorn2500
6.4 hemi
All 70 doin good,
Galion
Edmonton, AB
You're running 95 psi and the tpms isn't screaming at you for being way over pressure? Like the others said, that's way too high. Try 65-70 psi.
NorCal
Dang. Good info. I hadn't even thought about this. I was used to my car at 28psi
Brakelate
South/Central Utah
Depends on the year.
I was blessed... the '13 2500 has a "Light Load" switch that "dumbs down" the pressure alert point from 60 fr / 65rr to 60 fr / 45 rr. MUCH better ride, even on the already plush Power Wagon.
That said, I ran the stock BFG's around about 5k miles last summer aired down to 25 psi ALL the time (other than extended high speed towing). This is because I got sick and tired of sweating out and breaking my old knees and back airing back up with those wheezy ass low-volume gas station pumps every time I "aired down" to go down a long stretch of wash board road, or through some flour like blow sand that seems to be everywhere I want to go out here.
Of course, the TPSI went off with every re-start, but it was worth it. And, much to my surprise, the stock BFG A/T KO's never did heat up, wear funny or self destruct!
My buddies 2014 Power Wagon DID NOT come with the "Light Load" switch, and it makes him crazy. His too came from the factory with 90 psi all the way around. I told him what I was doing, and he thought I was a bit nuts. The new PW's come with different tires, so as usual, YMMV!!!
But, I told him to air his down to the minimal number on the factory door jamb sticker and deal and go from there. But, you want a better ride, no "wheel hop" off highway, and a 100X improvement in ride, air those suckers down. Just be prepared to ignore the warning chime, etc.
But, for everyone's safety, air all those suckers back UP before throwing a load in it or running freeway speeds (or both) up a twisty road.
And those, are my two cents... :favorites13:
SouthShoreRAM
you"ll burn up the center of your tire if over inflated.
i run max pressure as listed on sidewall of tire.
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
On the 3500 you can have a flat 0 PSI no warning lights or chimes? But if you toggle thru the Evic it will tell the PSI, but no warning now I find this ********.
